Nexus 5 not accepting a charge either from the wall outlet or a computer. It appears I have no connection to Koodo. What could be wrong?
This is a brand new phone, only bought last month.  I have tried plugging it with the original cord into the wall. I have rebooted the phone. I have tried plugging it in through the computer.  I'm really out of ideas.  Can anyone help please?
Photo of Shannon Holloway
Shannon Holloway
  • frustrated.
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 107,614 Points 100k badge 2x thumb
Hello Shanon
Have you tried another cord? Did you try another wall socket?
Photo of Dave
Dave
  • 7,814 Points 5k badge 2x thumb
since it is not accepting a connection from PC or a wall socket the first thing that I would suggest is another cord as Robert said. You can probably borrow another cord from a friend so you do not have to buy one - if you find that it is a problem with the cord it means that you can buy another one.
Did it just stop powering up all of a sudden? Has it been dropped recently - sometimes if it is dropped, it will not look like there was any damage but the plug in for the phone may have been damaged.
Photo of Mathieu
Mathieu, Mobile Master
If you have tried what Robert and Dave have said, bring it into a Koodo location for them to send it off for warranty work. As long as they do not see any signs of accidental damages the repairs would be covered by the manufacturer's warranty.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,898 Points 100k badge 2x thumb
Try gently and slightly pushing the connector that's plugged into the phone towards the front of the phone and hold it and see if it begins charging if not try the same in the opposite direction (towards the back of the phone). If it begins charging when you do this in either direction then the charging port has been damaged usually by using the phone while it's plugged in, this is not covered under warranty as its considered physical damage. Let us know if that is indeed the issue or if we need to keep trouble shooting.
Photo of Veronica
Veronica
  • 3,528 Points 3k badge 2x thumb
Hey Shannon,
Have any of the suggestions posted here worked? Can you charge your phone now?
Thanks!
