Nexus 5 died
  • Updated 2 years ago
My Nexus 5 (bought July 2015) just randomly died. the battery was partially charged when it died. I have tried pressing combinations of the power and volume buttons and nothing happens. Anything else I can try to restart it?
Photo of Janelle Penner
Janelle Penner
Posted 2 years ago
Photo of Chadwick
Chadwick, Mobile Master
  • 33,072 Points 20k badge 2x thumb
This happened to my nexus 5.
If the power button is stuck , tap the phone on a table softly about 10x. The power button may have gotten stuck down in the off position and needs to be knocked back into position. You can also try flicking the power button a few times.
If its dead not much you can do unless its under warranty. You could try leaving it on the charger for a day or so to see if that helps bring it back to life.
Janelle Penner
Never mind, I plugged it in again and it started up!
Janelle Penner
Thanks anyway!
Photo of Chadwick
Not a problem. The nexus 5 power issues are common. Tons of forums online about it.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,448 Points 100k badge 2x thumb
Another thing to try that I did to mine when it happened was to take the back off the phone and blow around the power button while tapping it with your finger then replace the back and away you go.
