Nexus 5 dialer problem
I have a problem with my dialer as the calls log, contacts and favorites don't get displayed..... It displays a white screen....!! Sometimes it displays correctly......what to do? Any advice?
Photo of Hossam
Hossam
  • 92 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Mitchell Palmater
Mitchell Palmater
  • 12,996 Points 10k badge 2x thumb
Sounds like you need to do a factory reset.
Unless someone else can suggest a different fix?
Normally if you develop a software bug over time it is best fixed with a reset.
Photo of Hossam
Hossam
Thanks, will this affect any of my stored contacts, photos....etc? I presume not as they are on gmail cloud...is that right?
Mitchell Palmater
If you are certain that everything is backed up to your google account then no you wont lose anything
But I'd recommend doube checking to be safe ;)
Photo of Hossam
Hossam
Thanks Mitchell
