Nexus 4. Phone is very quiet during a call
Although my volume during a call is at max, the volume is very quiet and I can barely hear anything
I try to adjust volume during call and it is already at max volume.
Sound is otherwise fine on phone, and is only quiet during call. What is wrong?
Photo of Melody Grey
Melody Grey
  • 80 Points 75 badge 2x thumb
Photo of Ivan
Ivan, Mobile Master
Media volume (music/video/games) is usually separate from voice call volume and notification/ringer volume. Have you ensured that the correct volume is at max? If you adjust your volume via the volume buttons during the call, it will adjust the in-call volume.
If the call volume is at max, have you tried using a headset? If so, is it quiet over the headset as well?
Melody Grey
The correct volume is at max during a call, as I try to adjust the volume with the side buttons but the volume is already at max.
I have tried a headset and the volume is fine, but convenience wise this isn't the best for me.
