New phone, same prepaid plan?
  • (Edited)
Hi! So I have a prepaid Koodo plan on my Nokia Lumia 520. I was looking to get a new phone, but I would like to keep the same plan. If I would be to purchase online an unlocked Nokia Lumia 1020, would I be able to switch to the new phone?
Photo of Stephanie Brunet
Stephanie Brunet
  • 82 Points 75 badge 2x thumb
  • unsure
Posted 3 years ago
Photo of Todd Leblanc
Todd Leblanc
  • 880 Points 500 badge 2x thumb
As long as it's. Compatible with the towers I don't see why you couldn't
Photo of Ahmad
Ahmad
Yup you certainly can. All you have to do is put your sim card from the 520 into the 1020 and you're good to go. If the 1020 takes a different sized sim card, which I dont believe it does, then you just have to purchase the appropriate sized sim card from a Koodo store/kiosk or retail location.
Stephanie Brunet
Thank you very much!
