Network connection
I'm currently looking at a new phone since I cracked my screen and I was wondering if a phone with a Network Band of GSM 850/900/1800/1900 MHz + 3G WCDMA 850/2100MHz would be able to run on the Koodo network with my sim?
Photo of Logan Murray
Logan Murray
  • 92 Points 75 badge 2x thumb
Photo of Marcel in O-Town
Marcel in O-Town
  • 3,722 Points 3k badge 2x thumb
certainly will...
Photo of Ivan
Ivan, Mobile Master
I wouldn't recommend it. Koodo (and other Big 3 brands) is on an 850/1900 network. Your coverage may be limited. I suggest a phone with both 850/1900 bands.
http://en.wikipedia.org/wiki/UMTS_fre...
http://en.wikipedia.org/wiki/List_of_...
Photo of capricorn
capricorn
  • 340 Points 250 badge 2x thumb
yes of course it should be run on koodo network since the band frequency is the same as koodo
Photo of Ivan
Ivan, Mobile Master
I just posted that that it's not the same > Koodo = 850/1900
Marcel in O-Town
and the phone logan mentioned has the 850 for voice/data, and 1900 for voice as well. since the 850 band is pretty much everywhere, there should be no problem... i have used an 850 mhz only phone with great success on koodo
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,222 Points 100k badge 2x thumb
Only on gsm, koodo uses wcdma and the frequencies listed for this phone are 850/2100
Logan Murray
Thanks for the replies, I'm not really sure which answer is correct though so if you guys could clear it up that'd be great! :)
The answer is that it will probably work, but not as well as one that supports both 850 and 1900 MHz for HSPA/WCDMA.
Logan Murray
Thank you!
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
Yup you have to keep in mind that Koodo does not have 2G/GSM available so you aren't getting the full reception based on the fact that phone doesn't have both bands Koodo uses.
