network problem
dear sir my htc one v drops network signal after 6-7 hours and when restart phone then comes back . when network drops i search manual and selected to home network then says ( your sim card does not allow a connection to this network)
pls help me soon as soon
Photo of HARJINDER
HARJINDER
  • 90 Points 75 badge 2x thumb
Photo of rikkster
rikkster, Mobile Master
Hi Harjinder,
It could be a problem with your SIM card. Power the phone off, remove and reinstall the SIM card making sure it is properly seated. Turn the phone back on. If you're still experiencing problems, the HTC One V takes a standard size SIM card and costs $20.
https://shop.koodomobile.com/browse-a...
Photo of HARJINDER
HARJINDER
dear sir i change alot times many sim cards but problem still.
after drops network i airplane mode on and after some time off the network work properly.
and one another way restart the phone.
what can i do sir ????
Photo of HARJINDER
HARJINDER
Photo of rikkster
Photo of bbud
bbud
I used to have the one v and it was a bug with the phone. The only way to get it back was to turn on airplane mode, restart the phone and then turn off airplane mode. Was so annoying that I got the moto g and have had no issues.
Photo of Mayumi
Mayumi, Mobile Master
  • 112,930 Points 100k badge 2x thumb
If different sim cards didn't fix connection problem, there is something wrong with your phone.
You can send it to repair, but it might cost you a lot if the warranty does not cover.
It would be a better to get a new phone as already mentioned .
