Network differences between Koodo, Public Mobile, and Telus?
  • Updated 7 months ago
  • (Edited)
Rather than posters speculating, is there any published public literature stating what, if any differences there are between the main Telus brand and it's flanker brands like Public Mobile and Koodo?
For example, it's been demonstrated in some locations, all things being equal with the same device and model where a Telus subscriber has cellular service and the Koodo or Public Mobile subscriber does not.
I don't think it would be unreasonable if premium subscribers have full access to cellular towers including services like VoLTE and those who pay less have some network features and channels blocked or restricted in favor of Telus subscribers?
Photo of Dwayne_888
Dwayne_888
  • 1,004 Points 1k badge 2x thumb
Posted 7 months ago
Photo of Dinh
Dinh, Mobile Master
  • 33,244 Points 20k badge 2x thumb
I want to see proper evidence. Even on the same network, 2 devices of the same type could lock in different towers.
Photo of Dinh
Dinh, Mobile Master
Did you change the SIM card between phones?
Photo of Robert
Robert, Mobile Master
  • 103,928 Points 100k badge 2x thumb
I would recommend using the same phone with both SIMs. If it' still the case then I would say that you found an exception.
Photo of Robert
Photo of Dinh
Dinh, Mobile Master
The permanent signal bar is gone, but when you are in field test mode*3001#12345#*, you still can go to TLE --> serving cell info, where you can see lots of info on the the current tower
I am on ios 11.0.3 and still can see that mode
Photo of Dwayne_888
Dwayne_888
You're right!  I had the above code saved as a favorite on my phone and with Rogers it was blocked. It works again!!!
Photo of Cory
Cory
  • 10,482 Points 10k badge 2x thumb
They operate on the exact same network, with no restrictions. There may be FEATURE differences such as VoLTE, however.
Unless you are testing in the exact same location with the EXACT SAME DEVICE, signal tests won’t be valid.
Photo of Dwayne_888
Dwayne_888
Do you have any evidence to state that there are no network restrictions? The competition has even gone so far to say that Koodo, Chatr, Virgin, don't have the same coverage as the premium carriers despite sharing towers.
Why the discrepancy then? ie. Koodo did not have service, Telus did in the same location, side-by-side in remote location?
I am thinking that Telus might not give Koodo access to all the same channels on the same tower/enhancer/repeater therefore they are being restrictive?
Photo of Allan
Allan, Mobile Master
  • 55,974 Points 50k badge 2x thumb
I've talked to Telus reps before who have told me Koodo and Telus share everything with no restrictions.
Photo of Dwayne_888
Dwayne_888
I think the Telus Reps in the Philippines don't know what they're talking about. For example, Telus has VoLTE and other network features Koodo does not.
Photo of Robert
  • 102,848 Points 100k badge 2x thumb
Having a feature enables does not change anything to the coverage in that particular area.
Photo of Bernard
Bernard, Official Rep
  • 74,962 Points 50k badge 2x thumb
@Dwayne, Cory has given the most precise answer above....including the statement re VoLTE. At least at this point.
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Telus, Koodo, and Public share the same network. The only factor it may change data speed is dependant on the frequency one phone is using from another phone. The best way to test this will be to have an android phone manually configured to use the same frequency, same model, and speedtested at the same time.
The only feature right now that is only available to Telus is VoLTE.
Photo of Dwayne_888
Dwayne_888
Jan Hope said it well. Does Telus prioritize access to their towers?  Should be the name of this thread.
Photo of Jan Hope
Jan Hope
  • 4,356 Points 4k badge 2x thumb
Hey to All,
They share the same network. The question is for example if Bell in Ontario don't prioritize access to its towers for Bell customers. Someone in Bell Store told me that they do.
I went to Tobermory and Bruce Pninsula National Park this summer and someone on Bell had connection almost everywhere in this area and even 3G data working and my phone was constantly disconnecting from network and finally lost total connection. I don't know why before I was disconnected I had some voice messages if I want to connect to AT&T.
Regarding data Telus/Koodo/PM share the same network with a exception to 3G plans on PM that have chatr like speeds. Chatr only offer 3G speeds.
I forgot to add that it is up to Koodo to implement VoLTE. They've had go ahead from Telus long time ago. I think it is not a priority for Koodo at this moment that is why it is probably on back burner at this moment.
Photo of Dwayne_888
Dwayne_888
Well put Jan,
I imagine PM probably had the go-ahead from Telus as well.
Photo of Jan Hope
Jan Hope
@Dwayne_888
Koodo is always the first. PM wish to have VoLTE but I think it may not happen soon for them if ever.
