Need to Turn Off TalkBack! Help!!!!
Got a Nexus 4, - accidentally turned on Talkback? so every time I touch on the screen it speaks what it is! Now trying to turn it off but when I go into Settings I cannot scroll the screen to get to the setting I need to turn it off. Any help would be appreciated! Many thanks.
Photo of Garry Cowdroy
Garry Cowdroy
Photo of Daniel Kim
Daniel Kim, Mobile Master
i found this.
1) Selections are made by long-tap then double-tap. Remember that, as you'll need it multiple times!
2) Select the Home screen (Remember the select technique?)
3) Select the app waffle-icon. (Remember?)
4) Use two (2) fingers to swipe through to the Settings icon, then select it. (Yeah, that's the ticket ... I remember now!)
5) Two-finger swipe to select Accessibility.
6) Select Talkback.
7) Select {on|off} toggle.
8) Select confirmation "OK".
so basically you need to do a two finger swipe to scroll down.
Photo of PD
  • 6,798 Points 5k badge 2x thumb
Select Talkback.
Select {on|off} toggle :)
