need help with poor credit
ok i have no credit im using bell plan right now
i own a koodo iPhone and also unlocked iphone both i want a plan but no contract im not getting any phone from koodo do they do a credit check will i be refused since i dont buy a tabbed phone from them can i get a plan monthly plan with no contract
Photo of Billy Nadeau
Billy Nadeau
  • 80 Points 75 badge 2x thumb
Photo of Sophia
Sophia, Mobile Master
  • 140,672 Points 100k badge 2x thumb
Hi Billy,
Yes, if you want a postpaid plan, there will be a credit check. You can visit a kiosk and they will be able to tell you where you're at with your possibilities - who knows you might get a "yes" - though they'll probably put you on a spending limit program.
An alternative is prepaid, which is actually quite awesome on Koodo - it's just like a plan really. What sort of minutes/data use are you looking at? Based on that, it will be easier to recommend a course of action for you :)
Photo of Jonathan I
Jonathan I, Mobile Master
The only way to find out what you're eligible for is to try it out anywhere that activates Koodo postpaid.
Billy Nadeau
i need high data and unlimited voice i travel canada a lot
Photo of Ahmad
  • 96,062 Points 50k badge 2x thumb
NO ONE here can tell you what is going to happen. You won't know if you will be approved or denied until you go in-store and attempt to activate a line. Good luck :)!
