Need help choosing a phone,,,
I need a new phone. I have bb number 2, and there are just too many problems. I need a basic phone, talk and txt is all I do. GO app is all I have on my phone. I don't need the internet... Thanks!
Marcia
Photo of Marcia Bacchus
Marcia Bacchus
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,666 Points 100k badge 2x thumb
The best basic phone Koodo carries is the Galaxy Ace 2x, then get a Data block put on your account and you can use it over wifi still if you want.
Marcia Bacchus
Thanks for replying. I will check it out..
It's an Android Smartphone but it's the best cheaper phone you'll find as there aren't many issues that have been reported with it. There are a couple of cheaper phones buy they have known issues. Like I said just put a data block on it and you'll be happy I'm sure.
