Need Help asp
Hello I have a problem, bought my wife a Huawei Y300-0151 loaded up on 1000 minutes and 4 gb on data. phone and internet work great , but data does not work. We brought it to Kios they reset the phone changed apn to koodo and still no data. What to do now. Could I change her sim card to a micro sim as I m looking at Nexus 5 for her. We are on prepaid. Thanks in advance.
Photo of claude lamoureux
claude lamoureux
  • 352 Points 250 badge 2x thumb
Photo of Brendan William
Brendan William
  • 732 Points 500 badge 2x thumb
was wifi off when trying to use data?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,012 Points 100k badge 2x thumb
You can certainly change the sim, but how exactly does internet work fine when data doesn't? The internet IS data.
It will stay there until you get a phone where the data works. If you wish, you can also try CALLING tech support to see if they can either get your data working or offer some kind of credit.
claude lamoureux
can I get a refund on the prepaid 4gb of data
claude lamoureux
Thank You ALL for trying to help. I think I will buy unlocked Moto G in the states when we go down, and change sim card when we return. do you think that will work
A factory unlocked moto g should work just fine. There have been several people on here who have purchased one and had no problems.
claude lamoureux
Thank You Timo
