need help
I cannot receive text messages
Photo of Regine Huettner
Regine Huettner
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
Do you have service on your phone , i mean can you make/receive calls ?
what about sending text messages ?
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Mat, please refrain from asking the same question. Thanks.
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
it's always good to ask that particular question because we didn't get feedback yet to understand what will be the next step? No question is bad and no answer is bad. lol
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
Get it solved! already asked the question which is why Yannick said what he said
Photo of MatB
MatB
and yannick already sait that !
Zaphod Beeblebrox
With the phone on, take the battery and sim card out for about a minute. Put it all back together and test. If that fails, a quick call to tech support can fix the issue. The permissions for text messaging might, somehow, be changed.
Photo of Dennis
Dennis, Mobile Master
  • 187,688 Points 100k badge 2x thumb
Do you have 3G turned off? Koodo does not use 2G, and uses 3G & 4G LTE only.
