Need to revive my Nexus 5!
Hello, its been 3 days that I am not able the get by Nexus 5 on! I cannot even charge it...it shows the battery sign but does not charge neither does it gets on. What should I do? Do I have to get a new internal battery? Also, where could I get it fix?
Thanks
Photo of Darshana Patel
Darshana Patel
Posted 3 years ago
Photo of rikkster
rikkster, Mobile Master
  • 67,084 Points 50k badge 2x thumb
If the phone is less than a year old, battery replacement is covered under the manufacturers warranty. Take your phone in to a Koodo shop to have it inspected to verify that it is in fact the battery causing problems. It's possible the charger may be at fault if you're not able to charge your Nexus 5. Also, try charging the phone from your computer via USB cable.
