Need to know what info is needed from work to save on bill
I was told that I can save 25% on my bill because of my place of employment, but I'm not sure what I need to give Koodo in order to get that. Would anyone know?
Photo of kdrsutherland
Posted 3 years ago
Photo of Not Jeff
Not Jeff
  • 2,058 Points 2k badge 2x thumb
Most often then not, your management team or human resources would have a contact person or group who would send that information on your behalf.
Otherwise, calling *611 will get you to the experts who may know of the process specific to your program or employer.
Some groups have email addresses you're supposed to send a form into that you would obtain from your human resources department.
Photo of Du
  • 3,762 Points 3k badge 2x thumb
You should probably talk to your IT or Cell phone guys at your company, if its from your company then *611 won't able to help much
Photo of Jonathan I
Jonathan I, Mobile Master
If you're at Loblaws/Superstore/Zehrs etc. you need to speak with Mobile Shop staff and they can send out the form for you. If your store doesn't have one, I can see if I can get it to you since I used to work for them.
As for Wal Mart, the Wal Mart electronics or mobile staff should be able to get that for you.
Photo of Paul Okrucky
Paul Okrucky
  • 82 Points 75 badge 2x thumb
Hi,You will need a Employee Purchase Plan:Enrloment Form signed by your Department Manager ,You can get one of these forms from yr phone people in the connection center.
