Need Online Help with Motto G .
I cannot get online with my motto g phone. It has a red triangle with plus sign up in corner and also looks like black squiggle line in grey box.
Photo of Jane Jackson
Jane Jackson
  • 192 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Daniel Kim
Daniel Kim, Mobile Master
The red triangle means you have no service but you are still able to place emergenc calls. Try taking your sim card out and reinserting it after about 30 seconds and reboot your device. By online, did you mean using data?
Jane Jackson
Yes using data. And not sure how to take my sim card out of phone. I am so new at this it's making me a bit nuts.
are you on prepaid? have you activated your phone yet?
Jane Jackson
Hi Chad, I pay monthly and phone bill is up to date if that's what your asking.
Jane Jackson
And yes phone is activated but for some reason now I am getting red triangle with plus sign in it. I can only make emergency calls right now.
Here's how to get at the Sim card
Make sure to power down the device first
http://m.youtube.com/watch?v=R-x5bmwyJwo
Jane Jackson
Yes I did take it out but it hasn't helped.
Goto settings.. Wireless and networks... More... Mobile networks...
Make sure
Use 2G only or use GSM only isn't selected
Data is enabled
Network selection is set to auto.
Did you try the above?
Jane Jackson
Hi Chad, Thanks, It was as u said 2G. I am all good now. Data enabled. Thanks a million! Jane
Wonderful, enjoy your phone.
Jane Jackson
My battery is not charging. I don't know why. Please help. Thanks!
Photo of Ivan
Ivan, Mobile Master
Please try a different USB cable and a different power source. Does the problem persist?
Jane Jackson
I've tried that. Still not working. Thanks!
Jane Jackson
Yes still have the problem.
Jane Jackson
Battery is at 95 % but still not charging in the Motto G phone.
Photo of rikkster
rikkster, Mobile Master
With your phone powered off completely and connected to your computer via USB, press and hold the Volume down button first, then press and hold the Power button (in that order) and hold together for about 15-20 seconds, then let go of both buttons. You should see a screen with blue text titled 'Boot Mode Selection Menu', (see image below).
Leave the phone on this screen for approximately 15 seconds, your computer should show a quick message that drivers are being installed, (assuming that you're running a Windows PC). After you've seen the message or the 15 seconds have elapsed, press the Volume Up button which will select Normal Powerup.
The phone will reboot and should be able to charge. At the top of your screen, you should see a lightning bolt or an animated battery filling up, indicating that the phone is charging.
Jane Jackson
Thank you for all help. I found out I was in the wrong network. I am now good to go.
Thanks so very much!
Jane
