Need Help with Plan Upgrade, where's my Data?
So I changed my plan from the basic one to the $45 a month one, I would say two weeks ago. However when I don't have a wifi connection and subsequently try to use data, nothing happens... I try to open the internet and am told I do not have a connection. Why is this when i have changed my plan to include data?
Photo of Charlotte Sophie
Charlotte Sophie
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 67,216 Points 50k badge 2x thumb
Make sure Mobile Data is enabled on your phone settings.
On a recent Android phone, it can be found in Settings => Connections => More Networks => Mobile Networks => Mobile data.
Photo of Ahmad
Ahmad
Since you've tagged that you're using an iPhone, I'll post how to do what Bob said but on the iPhone as the Android way would be useless to you.
Settings -> Cellular -> Cellular Data 'ON' (make sure its green). If this is already on, it could be blocked at the account level in which case I'd login to self-serve and see if you have the "Data Block" add-on. If so, go to change/remove add-ons, remove it and your data should work within a few minutes.
Charlotte Sophie
I followed your instructions, and it worked! Thanks so much :)
