Need help using my data
  • Updated 9 months ago
Photo of Shawna Stanley
Shawna Stanley
Posted 9 months ago
Photo of Robert
Robert, Mobile Master
  • 103,604 Points 100k badge 2x thumb
What can we help you with?
Photo of monica small
monica small
  • 60 Points
Do I pay for wifi
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
No.  If you can connect to any WIFI, it's free.
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
Wifi is just any internet connection that you can connect to. You don't pay any extra to use wifi on your phone. You do pay to use data on your phone (whether it's part of your plan or pay-per-use).
Shawna Stanley
Change my APN
From a telus
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,448 Points 100k badge 2x thumb
-Make sure your data is enabled on the phone in your settings menu.
-Make sure you have a valid data booster if you are on prepaid
-Make sure you do not have a data block on your account, you can check and remove it through your Koodo self serve account
-Make sure your APN settings are set to those of Koodo's (Koodo's APN settings below)
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Tap menu key, then tap Save. Make sure the radio button is selected to activate data.
Shawna Stanley
Can u call me 780xxx-xxxx
  • 199,364 Points 100k badge 2x thumb
This is a public forum and We are just customers like yourself not Koodo employees and as such we should not be privately calling other customers unfortunately.
As it is a public forum you may want to delete your phone number from here as well.
Shawna Stanley
It's a flip phone it's too old
Photo of David
David, Mobile Master
  • 88,598 Points 50k badge 2x thumb
Flip phones do not use data in the fashion smartphones do. There is no need to have a data package for a flip phone.
