Need help regarding iphone 5c
  • Updated 2 years ago
last night i change on here my sons plan from $28 one to a $40 one so he'd have data. still not allowing him any data however, even though it successfully changed on here.please advise how we can get the data working?
Photo of Kelly Bessette
Kelly Bessette
Posted 2 years ago
Photo of Mayumi
Mayumi, Mobile Master
  • 111,428 Points 100k badge 2x thumb
Is your phone from Koodo? Make sure your APN settings is set to Koodo.
Is your data on?
Also,check his plan's add-on if he has data block on his account. If it is, then remove it.
If you don't see it and those suggestion didn't work, call Koodo *611 option 6 for tech support.
Photo of Alaa
Alaa, Employee
  • 874 Points 500 badge 2x thumb
Hi Kelly !
Did you try Mayumi's suggestion ? Please note that if you still have the old data block add-on, it will not appear on Self-Serve even though it's still there. If that's the case, your best bet would be to contact us.
Keep us posted :) !
