Can't connect using non-Koodo phone
  • (Edited)
I HAD my phone unlocked from another company to use it for koodo, I put in the right apn number for koodo networking, but it won't let me connect to koodonetwork even with my koodo Sim card , why ??
Photo of Nolan Nicholson
Nolan Nicholson
  • anxious and need it fixed
Posted 3 years ago
Photo of Jonathan I
Jonathan I, Mobile Master
Make sure you have 3G enabled in the settings and not 2G. What phone is it? Be specific so we can check frequencies
Nolan Nicholson
It's a Samsung S4 MINI , where do I turn on 3?
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,580 Points 100k badge 2x thumb
HSPA connection allows you to use data as well it's just a slower connection.
Ok so you activated the SIM Card right?
If you activated it then try doing a battery and SIM Card pull for a minute or so then replace them and try it again, make sure the SIM Card is in the right way and that it's the proper sized SIM Card for the phone.
Is the phone working for anything, texts, calls?
Nolan Nicholson
I originally had my Sim card in an old phone but had to get this phone unlocked so I could use my Sim card in it. Nothing is working right now, the phone is unlocked with the right.apn for koodos network but every time I try to connect it says unable to connect try again later. How do u activate a Sim card
Nolan Nicholson
When I press koodo it says can't connect , so Iwon't get service or anything till it connects
So the SIM Card worked in another phone and you were using Koodo?
Photo of Jonathan I
Check out this website: protectyourdata.ca
Put in the IMEI of your phone, which can be found by going to "about phone" in settings or typing in *#06# into your phone dialer. Your phone may be blacklisted.
