need a manual or tutorial for android 5.1 on nexus 5!!
Bell has a great guide for the use of Nexus 5, BUT it does not comply with the update of android 5.1.
Anyone know of a guide for the android 5.1 on the Nexus 5
Photo of El-Palmar Beach-Resort
Posted 3 years ago
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
Yes it did the update to loopoop you have call goolge
request a call back from goolge nexus 5 not the best because worst system a valble I don't rekmend nexus
of the error Samsung or Sony expara not bad phone quit with less error message but ones time old problem as sealed in battery not smart thing
is vary dangerous thing just ask questions if there error
won't let you turn off they should tell you
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,554 Points 100k badge 2x thumb
Sorry don't know what the above response says at all so I'll direct you to YouTube, any time you want to learn anything just search YouTube
Paul, this is a link to the bell tutorial for use of the Nexus 5, android 4.4.
http://support.bell.ca/Mobility/Produ...
I would like to find something similar for Nexus 5, android 5.1
I did check youtube, a lot of good videos but not what I need.
Thanks, John.
Photo of rikkster
rikkster, Mobile Master
  • 68,330 Points 50k badge 2x thumb
Most of the tips from the Bell site tutorial are derived from Google's Nexus support site. I managed to find an Android 5.0 Quick Start Guide and there's also an app that offers helpful tips and provides proactive troubleshooting to help you get the most out of your Nexus 5.
Nexus Help Centre
https://support.google.com/nexus/#
Android 5.0 Quick Start Guide (pdf format)
https://static.googleusercontent.com/...
Device Assist (App)
https://play.google.com/store/apps/de...
Photo of Krisztina G
Krisztina G
  • 80 Points 75 badge 2x thumb
You are helpful Master !
Krisztina G
Can you tell me I phone 5c different and benefits between Samsung..É
Your time appreciate it and responde
Krisz
Photo of rikkster
Unfortunately, I can't answer your question because I have nothing to compare to the iPhone 5c. You have to provide the model name, (e.g. Samsung Galaxy S5), or the model number of your Samsung phone. It's also recommended you start a topic of your own so that you can get a quicker response from others in the community. Click the link below to start a new topic. :-)
http://community.koodomobile.com/kood...
