Navigation Problems
Is there a way to remove recent destinations on navigation on a Samsung Galaxy S II X phone?
Photo of Bob
Bob
  • 114 Points 100 badge 2x thumb
  • frustrated
Photo of Iglooman
Iglooman
  • 4,090 Points 4k badge 2x thumb
You can try this solution gleans from AndroidForums:
1. Settings
2. Applications
3. Manage Applications
4. Select Filter
5. Select All
6. Select "Maps" application. It will show the following
Total xxx MB
Application XXX MB
Data xxxMB if it is other than 0 this is your recent destinations
7. To clear recent destinations, select "clear data" button.
Photo of Bob
Bob
there is no manage applications on my phone
Photo of Iglooman
Iglooman
Here's how to find Manage Applications according to the Samsung S2 manual:
Once there, find the maps application and tap on it, then hit "Clear data"
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,312 Points 100k badge 2x thumb
Go into your settings Then click on application manager, slide sideways till you come to "All", scroll down to Maps and click on it, then tap the clear data. Tada No more recent places in the Nav App.
Photo of Bob
Bob
I tried to follow the instructions in the manual. I do not have the option manage applications. I have the Samsung Galaxy S II X phone, maybe the option to manage aplications is not included
Photo of Iglooman
Iglooman
You tapped on the settings gear, then on Applications to get to the next menu? Manage Applications should be there in the Applications Menu. Without it you have no way to remove applications off your phone. They wouldn't exclude it.
Follow exactly what I said above and it will work. Your going into the setting for the phone not the app to start right?
