My sister can not call me but I can call her. Her number on my phone has a circle A beside her number.
Photo of Denise Barrett
Denise Barrett
Photo of Dennis
Dennis, Mobile Master
  • 178,354 Points 100k badge 2x thumb
Are you both with koodo?
What phones do you both have?
Does it go to voicemail?
Does it happen to anyone else?
Photo of MatB
  • 32,458 Points 20k badge 2x thumb
Did you blocked her number on your phone, check blocked/rejected numbers in your block list
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 137,132 Points 100k badge 2x thumb
The circled A next to the contact shows that it has been set to auto-reject her calls. The easiest way to fix it would be to delete her contact and add her again. There is a way to simply switch it off auto-reject, but it often gets stuck and won't actually switch until you delete the contact anyway.
