Samsung Galaxy S2X doesn't turn on anymore
  • (Edited)
My galaxy s2x was getting really hot recently. So i went easy on the battery and didnt use data. then one day all of a sudden my phone got really hot in my pocket and turned off. so i turned it back on and checked the battery and it was 70%, so the battery was not the problem. then it got hot in my pocket again and the it turned off and this time it wouldnt turn on. i inserted another battery but it still didnt star . I dont know what the problem is. Is there a fix for this where i can save my contacts and apps that are on my phone?
Photo of Manav Patel
Manav Patel
Photo of Ahmad
Ahmad
If you bought the phone from Koodo less than a year ago, you can send the phone in for warranty service at any Koodo store/kiosk. If your phone is 'dead', there is no way to get any contacts. Apps you have downloaded will be in your history in the Google Play Story and can easily redownload from there once you get a new phone
