My Samsung galaxy ace does not allow me to answer my phone or unlock so I can use it at all. Please tell me what I can try to fix this.
I cannot even turn off the phone to try to reset it. I don't know what to try to get this fixed.
Photo of Michelle N Paul Tukutau
Photo of Dennis
Dennis, Mobile Master
  • 196,856 Points 100k badge 2x thumb
Pop out the battery and back in and turn it back on
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,746 Points 100k badge 2x thumb
If this is a new phone and you haven't been able to unlock the screen at all, you need to drag the lock icon across the screen to the right, not simply tap on it. Same to answer a call, drag the green phone icon to the right.
Photo of MatB
MatB
  • 32,478 Points 20k badge 2x thumb
Hard reset is needed in this case, press Volume Button +Power button at same time for 3 seconds. beware all personal data, apps, contacts will be lost.
Photo of AlexiKrov
AlexiKrov
  • 1,724 Points 1k badge 2x thumb
If the factory reset doesn't fix it, then send the phone in for repair.
