My Samsung Focus randomly restarts primarily when using data, is there a way to fix that?
Pretty much the title description, when it restarts I sometimes have to pull the battery out too, whats going on here?
Photo of Alexander Baird
Alexander Baird
Photo of Mo D.
Mo D.
  • 17,268 Points 10k badge 2x thumb
hmmm....
Well based on a quick read from here
(http://forums.wpcentral.com/samsung-f...)
it could be two things:
1) Running too hot and shutting down as a safety
2) Running out of memory and having to crash
I reeeeeaaaallly doubt it is the power button thing.
Possible solutions, try removing your case to let your phone breathe a little and see if it helps with overheating.
Most probably though it's a memory-filling issue. Try emptying out unnecessary data/files/open programs...etc... and buy an SD car to store your stuff on. Also change your Reserve Space from 1% to 20% through Zune, as suggested in the link.
Good luck
Photo of Sophia
Sophia, Mobile Master
A quick search shows that this is a common problem for the Samsung Focus :( However, the one good article I found is that it might be possible to find a fix: http://forums.wpcentral.com/samsung-f...
Try it and report back if that works... if not, you might need to get it fixed (if it is within the warrantee period)
Good luck Alexander :)
Photo of Mo D.
Mo D.
bahahahaha exact same link we both posted. Crazy coincidence. :P
Photo of Sophia
LOL! I noticed that :D I guess we use the same Google huh? :D
Alexander Baird
Thanks :) I'll give the bumping the reserve memory up since I don't use a case a try
Alexander Baird
Well unfortunatley those methods didn't work so I think it must be that its overheating, but thanks for the help :)
Photo of Sophia
Sorry to hear that Alexander, is it still within the warrantee period? You could have it fixed then... and otherwise perhaps treat yourself to a nice new phone :)
Alexander Baird
I think it has expired, so getting a new phone might be the best option. Thanks again :)
Photo of Mo D.
Mo D.
Sorry to hear that Alexander. Unfortunately the Focus isn't something we have direct experience with and I wish we could be of more help, but hey.... If you can upgrade, there are plenty of shiny toys to choose from :) ... Unless of course someone knows exactly how to solve it. Either way, good luck!
Photo of Prashant Kumar
Prashant Kumar
  • 60 Points
i am getting the same problem with my focus,,,,
just now hard reset it ,, and now the problem is resolved,,
maybe there was an issue with the memory , as last time i remember it had only 4 gb remaining ,,, so maybe there would have been some issue with that ,
thanks for helping ,, i really like internet ,, because dy these type of forums always help me :)
hope my comment would help any1 other too
