my Samsung ace II "messaging has stopped. How do I re-start?
Photo of Peter Wiltshire
Peter Wiltshire
  • 80 Points 75 badge 2x thumb
Have you tried restarting the device?
Peter Wiltshire
Yes I did. I also looked at application, settings for messaging and it looked fine
Photo of Byron Beltran
Byron Beltran
  • 256 Points 250 badge 2x thumb
Settings > Applications manager - select the All tab and as Chad mentioned, locate the Messaging app and clear it's cache. I used GO SMS Pro and it works quite well with the Ace 2x. Only other thing you'll have to do is turn off Notifications in your stock messaging app.
This is done by tapping Messaging envelope on your Home screen. Once inside the app, tap the Menu key to the left of the centre Home button, then tap Settings. Scroll down to the bottom of the page and uncheck the box under Notifications. This will prevent the Ace 2x from showing duplicate notifications when using GO SMS Pro.
In Go SMS Pro's advanced settings, there's also an option to completely override the stock messaging app.
GO SMS Pro:
https://play.google.com/store/apps/de...
Chomp SMS
Photo of John Lee
John Lee
Not too sure what kind of bug this is but sometimes a battery reset fixes most problems. Turn off your phone, then take out the battery, wait 30 seconds - 1 minute and then put it back in. Restart the device and see what happens.
