My q10 keyboard light isn't working. Is there a way of fixing it without taking it in for repair?
  • 2
  • Updated 2 years ago
Photo of Shayne Riepert
Shayne Riepert
  • 2
Photo of Rocky Balboa
Rocky Balboa
You may have to speak with Blackberry. Koodo doesn't regulate the hardware. We're the "middle guys". Only thing we would suggest is to send it in for repair.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,448 Points 100k badge 2x thumb
Did you check the settings and make sure you didn't accidentally turn off the keyboard back light. Check under keyboard or display sections for a setting.
Shayne Riepert
Not sure if you can do that in setting or I just can't figure it out
Photo of mattjs
mattjs
  • 15,658 Points 10k badge 2x thumb
There isn't an option in settings to turn on/off the keyboard backlight, it's controlled by an ambient sensor. If the keyboard backlight isn't coming on even while in the dark, the sensor might be broken.
Just call Koodo and have them facilitate a repair/swap. If Koodo works the same way as Rogers, they'll just send you a replacement device in the mail with a prepaid UPS/FedEx box to send the old one back. Quick & simple.
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
That would be a Priority Replacement which has a fee of $25
Photo of mattjs
mattjs
Sucks that Koodo is charging $25 for this. Rogers started charging for it as well recently, but my experience is that you can usually get it waived.
Zaphod Beeblebrox
Very true. It comes down to the agent and the account history. Physical location of the customer plays a role as well, expecially if they live in a rural area.
Photo of Sunday Jacobs
Sunday Jacobs
  • 72 Points
I want a Swap for my BlackBerry Q10 it's having keypad light issue. How do go about it am from Nigeria
Photo of Daniel
Daniel, Employee
  • 5,680 Points 5k badge 2x thumb
Hi Sunday! We don't offer repair options for when you are overseas. Your warranty can only be used while you are in Canada. Here is more information on the manufacturer's warranty just in case: http://koo.do/Kwarranty :)
Photo of Goran
Goran, Mobile Master
  • 90,564 Points 50k badge 2x thumb
Well you could always do the repair yourself. If it's broken there's just no way around it.
