My phone wont turn on
My phone is an android and it refuses to turn on or reset. When I turn it on, its supposed to go through four different screens before appearing to my home screen. Now when I turn it on it goes to the fourth screen then shuts off or stays on the fourth screen till I take out my battery, either way it wont turn on. Do I need a new phone or is this fixable?
Photo of Ellen Marie White
Ellen Marie White
Photo of Sophia
Sophia, Mobile Master
Hi Ellen,
What Android is it? You say "the 4th screen", can you be more specific? What does it show before it stops, and what do you see then?
You could try a factory reset or take it into a store to have it looked at, if you are still under warranty and if something is wrong with it, they'll know what to do :)
