my phone wont charge
i have a samsung galaxy s3 and every time i charge it, it wont charge unless u bend the wire in a wierd way but on my dads phone ( samsung s3 mini) he charges it and it charges easily i never dropped my phone and i also have a otter box just in case so if it fell it couldnt of been effected
Photo of Stavro Isho Albazi
Stavro Isho Albazi
Photo of rikkster
rikkster, Mobile Master
Sounds like either the usb cable or the charging port on your S3 may be damaged. Experiment with different usb cables to see if that fixes the problem. If it's the charging port that's damaged, you'll likely need to send the S3 in for repair.
