my phone is not showing h+ 3G help fix cant recieve calls
my nokia lumina is showing 4g at top corner and should be h+3G how do i fi this
Photo of Terrie Stiles
Terrie Stiles
  • 190 Points 100 badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,558 Points 100k badge 2x thumb
If your phones showing 4g it just means your in a 4g area which is a faster connection than 3g & that's it, it won't affect anything and will automatically switch from 4g to 3g when you leave the 4g area.
While the phones on try taking out the battery and SIM Card for a minute or so then replace them and try the phone again.
