My Phone has stopped vibrating for incoming calls
Photo of Meghan Mcconnell
Meghan Mcconnell
  • 260 Points 250 badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,560 Points 100k badge 2x thumb
If you have an android device, go to your dialer app (like your going to make a call) then press the menu button and select settings. There you'll see an option to vibrate when riding make sure it's checked off to enable it.
Meghan Mcconnell
the Vibrate option is turned on and the volume settings for the vibrate is high,
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Meghan, can you let us know if this has been resolved?
________________________
Meghan Mcconnell
No it has not been resolved. I looked at the warrenty information, and it is still under warenty as I bought it back in dec. I am not sure what to do from here on out. I have reset my settings and still no vibration when people phone me.
Photo of Dennis
Dennis, Mobile Master
  • 187,566 Points 100k badge 2x thumb
Sounds like the phone requires repair. Good thing it is under warranty (assuming there hasn't been any water or physical damage to it)
Bring into Koodo to start the warranty process. Or if you are not by a kiosk you can call Koodo 1-866-995-6636
Here are the details:
http://help.koodomobile.com/getting-s...
Photo of sahil gupta
sahil gupta
  • 60 Points
Even I m facing same problem my cell galaxy grand do not vibrates on incoming calls or messages even if it's on a vibration mode
