My nexus 4 can't receive pictures anymore. It used to work fine, how can I fix it?
  • 5
  • Doesn't Need an Answer
My Nexus 4 android phone simply cannot receive pictures anymore. When someone sends me a message i get a notification but if i click on it i go to the messages with the person but there's no picture. Can anyone help?
Photo of Trent Schawalder
Trent Schawalder
  • 150 Points 100 badge 2x thumb
  • 5
Photo of John Lee
John Lee
Is your data turned on? In order to send/receive picture messages, you must have data turned on. It won't use it but it requires the connection however applications running the background may use your data.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,496 Points 100k badge 2x thumb
Did you happen to turn data off on your phone? (Wifi doesn't count for picture messaging).
If data is still on, is it still working?
Make sure the apn is set to sp.koodo.com, the mmsc is http:/ /aliasredirect.net/proxy/koodo/mmsc, mms port is 74.49.0.18, and the mms port is 80.
Photo of FFS
FFS
  • 564 Points 500 badge 2x thumb
Maybe a stupid question but did you power cycle the device? Also, go into your Mobile Networks and reselect GSM. Possibly a refresh is needed? Good Luck. ")
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
Selecting GSM probably will not help as Koodo does not have a GSM network.
Photo of Lily PC
Lily PC
  • 60 Points
What does it mean by "unable to load the resource on nexus 4
Photo of rikkster
rikkster, Mobile Master
  • 68,218 Points 50k badge 2x thumb
Usually it's written this way: (example only) 'unable to load the resource android.content.res' and points to a specific resource that is not loading correctly. From there I can usually determine whether it's an app-based resource or a resource within the Android operating system that is causing the problem.
Photo of carmenn
carmenn
  • 132 Points 100 badge 2x thumb
I am having the same problem!! I do not have data, however my plan says I have free picture messaging. What do i do?
Also if I turn on the data then I am worried i will by accident connect to the internet through other apps, is there a way to prevent this?
Photo of Myke
Myke
Turn on & connect to wifi, then turn on mobile data to send/receive pictures.
Photo of carmenn
carmenn
so there is no way to send pictures if you are not in a wifi zone?
Photo of carmenn
carmenn
or there is no way to have data on but have it only restricted for MMS?
  • 142,386 Points 100k badge 2x thumb
No, there is no way to send them WITHOUT THE RISK OF USING DATA if you are outside of a wifi zone.
