my new samsung s3 has stopped receiving incoming text messages. it's very frustrating that I can't call in for help after 9 pm.
Photo of Jane Vallee
Jane Vallee
  • 80 Points 75 badge 2x thumb
  • frustrated
Photo of Moto G
Moto G
  • 6,066 Points 5k badge 2x thumb
You can try going into your settings and check to see if the Mobile Data box has a check mark in the box. If not tap the box until check mark appears
Photo of Mo D.
Mo D.
  • 17,268 Points 10k badge 2x thumb
Often, a restart or battery pull helps the device force a reconnect to a tower and gets you back on the road.
Hope you have tried that?
Jane Vallee
I have tried everything.....nothing has worked :(
Photo of Jonathan I
Jonathan I, Mobile Master
When the customer service # is available again, give tech support a call and ask what's going on.
The other thing it could be is a faulty SIM card... If tech can't figure it out then you could try replacing the SIM card and see if that fixes anything.
