My mobile data won't work (Galaxy S4) :(.
  • 2
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 1-866
I have done all of this so far:
- Restarted phone
- Battery pull
- Making sure no mobile data limits are set
- Uninstalled a data management app just to be sure
It hasn't worked for just over 24 hours. As mentioned, I'm using a Samsung Galaxy S4.
Photo of Jenn B
Jenn B
  • 2
Photo of samsvoc
samsvoc
  • 7,686 Points 5k badge 2x thumb
Jenn, did you get your phone from Koodo? If not, you'll have to disable the default apn settings and install new Koodo apn settings in order to get data to work.
APN: sp.koodo.com
Proxy server: 74.49.0.18
Port: 80
Username:
Password:
Server:
MMSC: http://aliasredirect.net/proxy/koodo/...
Port: 80
MCC : 302
MNC : 220
APN typ
Photo of Jenn B
Jenn B
Evidently, the problem is bigger than I originally thought. I'm not getting phone calls on it, either. I disabled my WiFI and was still able to get a text, but the same person tried to call me and nothing happened. I tried using Skype to call myself and that didn't work, either. However, I was able to make an outgoing call (again, not on WiFI).
Also, yes, I got my phone from Koodo :).
Edit: Did a factory reset. Didn't help.
Photo of Mayumi
Mayumi, Mobile Master
  • 114,740 Points 100k badge 2x thumb
I would call customer service. 1-866-995-6636 or you can dial *611 from your Koodo phone ( Option 6 for technical support )
