my MMS dosent work after I factory reset my koodo nokia 610
I can no longer send or receive pictures
Photo of Dale Hardy
Dale Hardy
Photo of MatB
MatB
  • 32,478 Points 20k badge 2x thumb
Hi Dale !
Supposedly, it should work, is your phone Koodo phone, if not, verify APN it should be set to: sp.koodo.com, MMS should be set to http://aliasredirect.net/proxy/koodo/... and this number (+16475800172) on messaging center, enable Data, Powercycle and try again
Photo of Boolanger
Boolanger
  • 9,234 Points 5k badge 2x thumb
Hi Dale
download the Nokia Network setup app. here; Network Setup
Once it is installed it should allow you to select your carrier and it will set the APNs for you
Photo of Dale Hardy
Dale Hardy
App not available for my phone :(
Photo of Boolanger
Boolanger
Hmmm. Give this link a try, http://www.windowsphone.com/en-ca/sto...
the other was for the US marketplace
Photo of Dale Hardy
Dale Hardy
again says not available for my phone :( thanks boolanger
Photo of Boolanger
Boolanger
Well that is odd, wonder why that is, as it is meant for Nokia on WP 7.5.
Well you might have an issue then as if i recall correctly you cannot manually enter the APN info for MMS on WP7 only the data apns.
You may want to give tech support a call to see if they can assist, if I do remember correctly about you not being able to manually enter the mms APN info
Photo of Reena
Reena
  • 4,244 Points 4k badge 2x thumb
Hi Dale
Try this:
APN: Enter sp.koodo.com
User name: Enter Koodo
Password: (not mandatory)
Port server/URL: Enter 74.49.0.18
Proxy port: Enter 80
Photo of Dale Hardy
Dale Hardy
no go .. didn't work Reena .. thanks thou
I beleive there is a Firmware update to 7.8 for that phone. You may want to check to see if you're running the latest firmware, if not update it and try again. Here's a link on how to update the firmware.
http://www.nokia.com/global/support/s...
On the older firmware you could not edit the MMS portion of the APN for some insane reason, without the tool. but I believe you can indeed edit the APN with 7.8 installed.
