my messaging on my samsung galaxy ace 2 has stopped working. What is wrong with it?
Everytime i try to go into messaging it says "messaging has stopped"
Photo of Ezzie Bp
Ezzie Bp
  • 182 Points 100 badge 2x thumb
Photo of Ezzie Bp
Ezzie Bp
Please someone help me.
Photo of Yannick
Yannick
Hi Ezzie, you should remove the battery for a minute while the phone is on, then try again. This usually solves most of the basic technical issues. If it doesn’t work, give us a call at 1-866-995-6636 from a landline and select #6. A rep will have a look into it. Thank you!
________________________
Photo of Jonathan I
Jonathan I, Mobile Master
Keep in mind the Ace II X also has limited internal memory. If you have too many apps downloaded, music stored, or you keep too many old messages from previous conversations then it may clog up the phone.
Go to Messaging > Settings > General > Delete old messages set to... 300 or less and see if the app becomes more stable.
