my lg g2 is not working what do i do
well i had my LG G2 and i recently got the screen replaced and now the phone looks like it froze and none of the buttons are working and the screens not responsive but the screen is still on and cannot be turned off and i don't know how to fix it :/
Photo of Logan Switzer
Logan Switzer
  • 90 Points 75 badge 2x thumb
  • frustrated
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,132 Points 100k badge 2x thumb
try holding down the power button for at least 10 seconds. That will usually trigger an emergency restart and reboot the phone.
Logan Switzer
the power button and the volume buttons are not working either
Photo of Jonathan I
Jonathan I, Mobile Master
I would take it back to the place you got it repaired from. That doesn't sound right.
Logan Switzer
I fixed it by letting the battery drain and turning the phone on and now it works fine now thanks for the help thow
If the phone is frozen the power button will not seem to do anything when you press it. It will still shut the phone down if you hold it long enough.
