my koodoo lg phone is stuck on emergency mode with yellow screen
  • Updated 1 year ago
  • Doesn't Need an Answer
Help
Photo of Stephanie LeFait
Stephanie LeFait
Photo of Ahmad
Ahmad
Is your phone rooted?
Photo of Annette Liles
Annette Liles
  • 174 Points 100 badge 2x thumb
What does rooted mean
If it's the LG Optimus One, you'll need to get into recovery and run a factory reset.
If it's the Optimus Black, getting into recovery is near impossible without the LG support software which according to what I'm reading on Google doesn't work correctly. If you're under warranty, I would suggest getting in warranty service thru koodo. If you're out of warranty I'm afraid not much can be done.
If, As Ahmad asked, you're rooted:
Open recovery and delete the Dalvik cache and the cache partition and attempt a restart. Didn't work? Back in to recovery and re flash your rom if it's a custom rom.
If that didn't work:
If you have a Nand backup (and you should) restore it.
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Stephanie, is your phone working now? Keep us updated!
________________________
Photo of Russ Little
Russ Little
no idea what rooted is or how to get into recovery. tried taking out sim and restarting etc stupid yellow screen and no response to anything
Photo of johndoe1234
johndoe1234
The emergency mode screen is usually an indicator of software failure. What model LG do you have?
