My iPhone 4Not receiving messages help!!!!!
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
Ok I can revive all messages but except messages from people that have iPods and if I turn iMessage on I will recive messages from iPods but not from other phones when I don't have wifi... Is there a possible way to fix it
Photo of Francheska Ruiz
Francheska Ruiz
  • 362 Points 250 badge 2x thumb
  • confused
Photo of PZABOY
  • 5,142 Points 5k badge 2x thumb
well iMessage must be enabled in order to receive texts from ipods at any time, and iMessage only works on data, so if you dont have a data plan you have to have wifi in order for that to work. As for regular text messages form other phones you must have cell phone coverage to send and receive. If your having an issue trying turning the iphone off for 30 seconds then back on. If you have plenty cell coverage and the reboot still doesnt work work i would suggest calling *611 from your cell tomorrow once koodo opens to try some trouble shooting steps.
Photo of Jonathan I
Jonathan I, Mobile Master
Settings > General > Cellular > Enable 3G must be on. You can turn off data if you want but 3G must remain active or your phone is basically an iPod touch because Koodo does not use a 2G network.
If that still doesn't work, then a call to customer service like PZABOY mentioned, is your best bet.
