my htc one v will not turn on but if i hole the power button down it will light up but that is it
my htc one v will not turn on but if i hole the power button down it will light up but that is it. it was working fine this morning and now nothing, even when i plug it in the charging light doesnt even come on.
Photo of Jeremy
Jeremy
  • frustrated
Photo of Jeremy
Jeremy
any one know how to fix it? cuz i can not take out the battery on this phone :(
Photo of rikkster
rikkster, Mobile Master
If your HTC One V becomes unresponsive or doesn't perform as expected, you can perform a hard reset to return it to a factory default state.
Important: A hard reset will delete your data, apps and settings.
Press and hold the Volume down button, then press and hold the Power button. Keep the buttons held down until the boot menu appears.
Scroll to FACTORY RESET by pressing the Volume down button.
Press the Power button (acts like an Enter or Return button)
The phone will reset and reboot to the initial setup screen.
Photo of Jeremy
Jeremy
still not working :(, thanks though
Photo of Khushboo Choudhury
Khushboo Choudhury
  • 60 Points
does the fast boot option save my files?
Your files are preserved unless you execute a factory reset.
Photo of Debby Olivier
Debby Olivier
  • 236 Points 100 badge 2x thumb
Looks like you will need to contact technical support for a Priority replacement exchange if your phone is in the warranty period
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Debbie, he could also go the delayed exchange option as well :).
________________________
If you see a good answer, give it a star
Photo of Jeremy
Jeremy
thanks debby, my phone is still under warranty, and Mykec what is the delayed exchange option?
Photo of Tayeb A
Tayeb A, Employee
  • 18,208 Points 10k badge 2x thumb
Hey Jeremy :) The delayed exchange option allows customers to return their defective device and have a replacement device mailed to them.
