my 4g is not working on my ace 2 help
Photo of Joshua Latiff
Joshua Latiff
  • 80 Points 75 badge 2x thumb
Photo of Camilo_A
  • 30,138 Points 20k badge 2x thumb
Hi there... You may start by turning off your phone, removing the battery and after a couple of seconds just put everything back in and turn on on again, make sure the data packet is enabled by going to Settings / More settings / Mobile Networks and the enable the data...
Make sure you have enough signal bars, if is till not working, you may try to contact Technical Support for troubleshooting
Photo of Dennis
Dennis, Mobile Master
  • 177,710 Points 100k badge 2x thumb
I dont believe the Ace 2 has 4G
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 136,982 Points 100k badge 2x thumb
It won't support LTE, but 4G is likely what it displays on the phone.
Joshua Latiff
It does it was working fine until yesterday and i have my data plan on but the 4g wont show up or work
  • 203,644 Points 100k badge 2x thumb
Check your apn settings. Make sure koodo.sp is selected.
Settings --- wireless and networks -- more -- mobile networks -- access point names
Photo of Khaleila
  • 4,102 Points 4k badge 2x thumb
Hi Joshua, Is everything working fine now? Please keep us posted.
