My texts sometimes randomly get stuck 'sending'.
  • Updated 1 week ago
Texts can be going through fine, but then a series of mine -- like two or three -- get stuck.  Yet while they are stuck 'sending',  I still receive texts.  If I reboot, some of them will go, but usually one or so is still 'unsent'.  Using Moto G4 Plus. Vancouver Island.  Full data, text and LD plan.
Photo of Jamie
Jamie
  • 80 Points 75 badge 2x thumb
Posted 1 week ago
Photo of Goran
Goran, Mobile Master
  • 90,800 Points 50k badge 2x thumb
You can try reseating your sim card and restarting your phone. If that doesn't help can you try using another messaging app to send sms's and see if the problem continues? If it does, you can send a private message to Koodo via Facebook Messenger or DM via Twitter to see if there's anything they ca. Do on their end.
Photo of Jamie
Jamie
Thanks, I'll try that.  Do I need to remove the battery too when re-starting?  What other messaging app do you suggest?  I'm using Android messaging ATM.
Photo of Goran
You can try Chomp of Handcent. No need to remove the battery. But you can.
