My Samsung S4 phone volume won't stay on
  • Updated 2 years ago
the volume level I've set. The phone rings and I can't hear it. I check the volume and it is really low. It changes on its own. WHY???
Photo of Edith
Edith
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 90,654 Points 50k badge 2x thumb
You probably picket change the volume. Does it change if you leave it laying on a table after a while or something ?
Photo of Edith
Edith
Yes it happens then. What is 'picket change'?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,052 Points 100k badge 2x thumb
*pocket
Photo of Goran
Pocket dialed sorry. Lately my phone'S keyboard auto finishes the wrong thing a lot and I miss it.
Photo of rikkster
rikkster, Mobile Master
  • 67,084 Points 50k badge 2x thumb
If you're continuing to experience problems with volume levels, download the app Volume Ace from the Google Play store. The app shows all of the phones' volume levels. A widget can be placed on your homescreen to instantly show all volume levels at a glance.
https://play.google.com/store/apps/de...
If you have a cell phone case where the volume up/down keys are molded into the case, inspect the areas where the case touches the volume buttons. The case could be pressing too hard on the volume down button or, the case may not be seated correctly over the volume down button. Remove the case and re-install. Set your volume levels and monitor for any changes.
Photo of Goran
Beyond that it could be a flaw with the OS and appears to be acknowledged as an uncommon bug from Samsung but a update was supposed to be been sent several months ago. Do you know about when it started and if there was some update you installed or some app?
