My Samsung galaxy s5 picture message issue
My Samsung galaxy is five is having trouble receiving picture messages it says I receive them but want to go to click on the message nothings there how do I fix this please help
Photo of Jennifer Korosec
Jennifer Korosec
Is your network data enabled ? Picture messages require data to download the message. If you're worried about charges for data then connect to wifi before turning your data on. Just remember to shut it off before disconnection from wifi.
Jennifer Korosec
My data is on. I'm wondering what's wrong because I was having issues receiving a few pictures from one person but got ones from others no problems
Photo of John Lee
John Lee
Does that person have their data on in order to send photos?
Jennifer Korosec
I believe he's data is always on. Never had issues till the other day
Photo of Du
Du
  • 3,762 Points 3k badge 2x thumb
had similar issue very recently...might be your APN configuration?? double check it might help...
Jennifer Korosec
I'm not sure how to do that
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Jennifer,
To check the APN settings on your S5 you do the following:
Click Settings>Mobile Data - Access Point Names>click on the Koodo APN then check all the settings to make sure they're correct.
Here's the link for the Koodo APN details (click on Android):
http://help.koodomobile.com/plans-add...
Hope that helps :)
Photo of Stefania Cinti
Stefania Cinti
  • 60 Points
The same thing is happening to me with my S4.
I checked the APN settings as Daniel suggested and mine all match fine. I got the phone less than a week a go so I doubt anything changed.
