My phones data and wifi aren't working
  • Updated 2 years ago
My phones data and wifi aren't working. At first, I thought it was just a problem with my wifi box, so I plugged and unplugged it multiple times, still nothing. All the computers in my house are working perfectly fine as well. So I tried restarting my phone. Nothing. Then I tried turning off wifi and using my data instead but still got the same blank response. It shows that it's connected and has 3 bars for my wifi, and I have full bars of service for data, so I'm confused as to why it isn't working. It's most likely an issue with my phone (iPhone 6s),but does anyone know how I can fix this?
Photo of jessica
jessica
Posted 2 years ago
Photo of David
David, Mobile Master
  • 93,470 Points 50k badge 2x thumb
Have you tried "Forget this Wi-Fi network", and re-installing it?
You haven't put it in Airplane mode in error?
Have you restarted your phone?
Photo of Chadwick
Chadwick, Mobile Master
  • 33,092 Points 20k badge 2x thumb
Sorry to hear your having this issue. I see that you stated you have restarted your phone and it still is not working. I would recommend backing up your phone in Itunes or via Icloud.
If "forgetting this network" doesnt work. You can try a factory reset of your phone. That will fix it most of the time! Best of luck
Photo of rikkster
rikkster, Mobile Master
  • 68,314 Points 50k badge 2x thumb
Try resetting network settings. Tap Settings > General - scroll down to and tap Reset. Tap Reset Network Settings and again, tap Reset Network Settings. Your iPhone 6s will reboot and you'll need to re-enter your Wi-Fi password. This may also clear up the issue you're having with data.
Photo of Daniel
Daniel, Employee
  • 5,714 Points 5k badge 2x thumb
Hi Jessica!
Have you been able to access W-fi and data yet? If not, we'll do our best to get to the bottom of this. Keep us posted :)
