My phone won't send or receive picture messages ...my cellular data is on and I am connected to Wi-Fi ...so why won't it work
  • 2
  • Updated 9 months ago
Photo of Amanda Darke
Amanda Darke
  • 80 Points 75 badge 2x thumb
Posted 9 months ago
  • 2
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Hi Amanda, you can not send photos and video texts over wifi it needs to be sent received over your data connection.
Also make sure your APN settings are set to those of Koodo's specifications. See below
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Tap menu key, then tap Save. Make sure the radio button is selected to activate data. The frequencies are compatible so it should work.
Photo of Robert
Robert, Mobile Master
  • 103,784 Points 100k badge 2x thumb
If the APN settings are correct and you cannot send MMS, then there might be another problem. Have you ever succeeded sending MMS before?
PS : Paul she said her data was already on.
Yeah that is at the end of a canned response if it's already on the user can just ignore that one sentence at the end of the paragraph.
Photo of BobTheElectrician
BobTheElectrician
  • 62,114 Points 50k badge 2x thumb
Turn off wifi while dealing with the picture part of messages. Some phones will auto-disconnect from mobile data when wifi is available. A mobile data connection is necessary for the pictures to work.
Photo of Robert Emmerson
Robert Emmerson
I'm having the same problem. Can send messages but pictures don't work. I just moved my SIM card to a new phone (LG G4) and since then pics don't get sent.
I've got the APN settings added and turned data on and turned Wi-Fi off and reset network settings but still a problem.
