my phone says mobile network not available when i try to place any calls how can i fix this?
  • 2
  • Updated 2 years ago
acatel idol monthly plan
Photo of Sylina Thornton
Sylina Thornton
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
  • 2
First thing to try is powering down your device and removing the sim card and, if possible, the battery Wait a minute and then reinstall the sim and battery. Restart your device.
Didn't work?
Check and be sure you're not in Airplane or Flight Mode.
Still not working?
Navigate to your settings and mobile network settings.
Be sure that:
Network Selection is set to Automatic
USE 2G Only or USE GSM ONLY isn't selected
Network type typically should be "GSM\WCDMA PREFERRED"
Still not working?
Change NETWORK SELECTION to Manual
The device will perform a scan which could take up to 2 minutes. You'll be presented with a list of available networks. Choose Koodo or Telus from this list.Note: Doing this disables international roaming. Should you ever want to roam in the future you'll need to change this setting back to automatic
If your device still isn't working, check and be sure your bill is paid up and then give Tech support a call. It's free.
Hours of Operation
Monday - Friday: 10am - 9pm
Saturday: 9am - 7pm
Sunday: 9am - 7pm
Photo of Julie
Julie, Official Rep
  • 2,344 Points 2k badge 2x thumb
Hey Sylina! Were you able to get your network issue resolved thanks to Chad's tips? If so, which one has worked for you? Let us know if you need further assistance :)!
