My phone is not working.
Why is my phone not working? I bought it on September 12, 2014. I paid for the "CAN Talk & text 100min $29" plan the same day.
Photo of Ben Gehring
Ben Gehring
Photo of Robert
Robert, Mobile Master
  • 106,876 Points 100k badge 2x thumb
Did the guy in the shop set it up for you? HAve you activated your line?
Photo of Dennis
Dennis, Mobile Master
  • 196,080 Points 100k badge 2x thumb
What exactly is not working?
Is it no service?
Is the phone not turning on?
What phone is it?
Walk us through what happened when you bought it and whats going on now?
Ben Gehring
I have no bars. So nothing
Photo of Sophia
Sophia, Mobile Master
Can you answer Robert and Dennis' questions, please Ben? It's a bit hard to troubleshoot when we literally know nothing about your particular problem :)
Ben Gehring
And the guy did everything for me
Photo of Billy
Billy
  • 584 Points 500 badge 2x thumb
your phone is not activated yet.
check your sim card, under the koodo logo does it say "Prepaid"
if it does, most likely you will need to activate your phone.
go to activateprepaid.koodomobile.com
Photo of Billy
Billy
If you paid for the plan the same day, then 90% you're on prepaid but check just in case
Photo of Dennis
  • 196,006 Points 100k badge 2x thumb
Except that it sounds like Ben had service when he left future shop.
Is that correct Ben?
Billy, I'm sure it's not prepaid since there is no $29 prepaid plan nor any combination of prepaid base plan plus booster to add up to $29
Ben Gehring
I didn't turn it on at the store, I did it later(about 10 hours)
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Ben,
When you got the phone, did you get it on prepaid or did you get it with a tab? If you are having issues with the phone itself you can always call tech support and see if they can troubleshoot the issue. Or if you have access to your self serve account you can try activating your sim card, it sounds like something went wrong when it was initially set up. Try to provide a bit more detail so we can help give you a solution to this problem.
Photo of Yannick
Yannick
Hi Ben, the best would be to contact us directly over so we can check what's happening. We can be reached at 1-866-995-6636 from another phone, option #6. Thank you!
________________________
Ben Gehring
How do I call this number with no service?
Ben Gehring
And I don't have a home phone
Daniel Gunn
You will have to find another means of calling the number if you can, that would be your only option unfortunately.
Photo of Dennis
VOIP
Google Hangouts
Skype
