My phone cannot send a pictures!!!help pls!
  • 2
  • Updated 2 years ago
Photo of cindy
cindy
Posted 2 years ago
  • 2
Photo of Chadwick
Chadwick, Mobile Master
  • 33,092 Points 20k badge 2x thumb
Hello Cindy. Please make sure you do not have a data block on your account from the past. Also the data toggle has to be turned on for picture messaging to work
Photo of cindy
cindy
How to check my data toggle is on or off?
Tnx for reply
Photo of Mayumi
Mayumi, Mobile Master
  • 115,070 Points 100k badge 2x thumb
I just noticed you have an iPhone.
If you want to use imessage, then you will need wifi or data connection.
Photo of Chadwick
Keep in mind that as soon as u enable data, apps running in the background can cause extra charges. My best advice is set applications to only update over WiFi and to shut off background app data. Not sure how on an iPhone but YouTube will be able to help for sure.
Photo of David
David, Mobile Master
  • 93,768 Points 50k badge 2x thumb
on iPhone go to Settings > Cellular > then slide the button for each app you want to access / not access the cellular network under the 'Use Cellular Data For:' section.
Photo of David
To turn Cellular data on, go to Settings > Cellular and slide the button marked Cellular Data.
Photo of Tayeb A
Tayeb A, Employee
  • 18,208 Points 10k badge 2x thumb
Hey Cindy,
Have you tried the above suggestions? Do you still need help?
Keep us posted!
